New Product: Load Cells
The high-accuracy LCR Series S-beam load cells have a five-point NIST traceable calibration.
Protected to IP55, the load cells are constructed of lightweight aluminum for ranges up to 1,000 lb and stainless steel for ranges over 1,000 lb. An IR 0.25% interchangeability makes the cells suitable for multiple load-cell applications. Supplied with a 20-ft, four-conductor jacketed cable, the S-Beam load cells are used in tension and tension calibration is provided.
Omega Engineering Inc., One Omega Dr., Stamford, CT 06907, (800) 826-6342, omega.com
