Extended-Temperature I/O
The 750 Series I/O system now operates in an extended temperature range of –4 to 140°F.
The 750 Series I/O system now operates in an extended temperature range of 4 to 140°F. The system includes fieldbus couplers (for CANopen, Modbus, Ethernet - both Ethernet/IP and Modbus/TCP or UDP, digital and analog I/O modules, and special function modules. The modules have two, four, or eight-channel granularity in a compact package.
Wago Corp., N120 W19129 Freistadt Rd., Germantown, WI 53022, (800) 346-7245, wago.com
