The adhesive readily bonds to itself, metals, silica, sapphire, alumina, ceramic, glass, and plastics. It is resistant to salt solutions, mild acids and alkalis, and chemicals such as petroleum solvents, lubricating oils, and alcohol. Tra-Bond 2158 can be heat or room-temperature cured and is suitable for staking transistors, diodes, resistors, integrated circuits, and heat-sensitive components.
Tra-Con, 45 Wiggins Ave., Bedford, MA 01730, (800) 872-2661, tra-con.com
