Lead-free bearing material
DP30 high-performance, lead-free bearing material is designed for applications such as hydraulic systems, planetary gears, compressors, and gear pumps.
The material structure features a rigid steel backing bonded to a porous bronze sinter layer impregnated with a polymer-filled PTFE bearing lining. DP30 is available as cylindrical and flanged bushes, thrust washers, and strip and custom parts.
GGB Inc.
Box 189, 700 Mid Atlantic Pkwy.
Thorofare, NJ 08086
(856) 848-3200
www.usa.ggbearings.com
