Power Converter Module
High-frequency E-grade ZCS and ZVS switching dc/dc converter modules provide high power density with low noise and high efficiency and are priced approximately 15% below C-grade versions.
The converters come in four different inputvoltage ranges, seven different output voltages, and three package sizes of quarter, half, and full brick. Different base plate and pin options are readily available. Efficiency ranges from 80 to 90% depending on output voltage. Operating temperature range is 10 to 100°C with storage temperature range from 20 to 125°C.
Vicor Corp., 25 Frontage Rd., Andover, MA 01810, (800) 735-6200, vicorpower.com
