Single-Platform Connector
The MultiWise Connector combines pins, contacts, and blades on a single platform for greater conductivity and functionality.
The connector uses a pick-and-place process that preserves uniform connector plating. The connector elements are never cut so they are never subject to corrosion. A shake-insertion assembly method ensures precise perpendicular blade-receptacle configurations.
Onanon Inc., 373 Sinclair Rd., Milpitas, CA 95035, (408) 262-8990, onanon.com
