Double-Level Screw Terminal Blocks
UTTB double-level screw terminal blocks increase wiring density, providing a space-saving alternative to standard feed-through terminal blocks.
Sept. 14, 2006
The UTTB 4 connects conductor crosssection ranges of 0.14 to 4 mm2 and the UTTB 2.5 connects ones of 0.14 to 2.5 mm2. A universal FBS plug-in bridge system allows cross connections to neighboring feedthrough terminal blocks. And bridging from the upper level to the lower level can be accomplished with a special FBS component.
Phoenix Contact Inc. USA, 586 Fulling Mill Rd., Middletown, PA 17057, (717) 944-1300, phoenixcon.com
