Mechanical Product: Spring-Applied Brakes
The brakes’ hub and disk are one piece. Contact takes place on only one side of the disk, which results in no drag, contact, or noise when the brake is released. Additional features include: special friction material and high-efficiency flux path permit 4.5 to 18 lb-in. of torque in a 2 to 3-in. diameter; single-face engagement and disengagement for quick torque buildup and quick release; and elimination of brake cover plate reduces length.
Ogura Industrial Corp.
100 Randolph Rd.
Somerset, NJ 08875
(732) 271-7310
ogura-clutch.com
