575 Vac Motors and Drives
The Marathon Blue Chop XRI motor is available in 15 to 100-hp sizes and meets NEMA premium efficiency levels.
The 575-V models are available in sizes from 0.5 to 30 hp. The 575V GS2 variable frequency ac drives offer dynamic braking, PID, and a removable keypad. The drives can be configured using either the built-in digital keypad or the standard RS485 serial communications port. GS2 drives are equipped with one programmable analog input and output, six digital inputs, and two relay outputs.
Automation Direct, 3505 Hutchinson Rd., Cumming, GA 30040, (770) 889-2858, www.automationdirect.com
