Flowmeter Provides Three Outputs
The ST75 Series flowmeter measures and monitors air or gas flows, and provides outputs for mass flow rate, total flow, and media temperature.
The unit has a nonclogging sensing element with little thermal dispersion, microprocessor-based electronics, and reduced installation complexity and maintenance. The flowmeter comes in nine configurations between 0.25 and 2 in. (6 to 51 mm) in standard T-fittings, either NPT or tube, for quick, easy in-line installation. It services a wide flow range, from 0.008 to 839 scfm (0.013 to 1425 NCMH) depending on line size, making it well suited for low-flow and high-flow applications.
Fluid Components International,
1755 La Costa Meadows Dr.,
San Marcos, CA 92078,
(800) 863-8703,
fluidcomponents.com
