Submicro AC Drives
The FM50 Series of submicro ac drives operate motors from 1/4 to 3 hp. Voltage ratings include 115 or 230 Vac, single or 3φ inputs, or 460-Vac 3φ input with 230 or 460-Vac 3φ output.
The 115 and 230-Vac 1φ input models connect to commonly available two-wire 1φ power, yet provide 3φ output to the motor. Four digital inputs, two digital outputs, one analog input, and one analog output provide programmable interfaces compatible to almost any external device. All FM50 models include electronic overload protection and stall prevention, ground fault and short-circuit protection, and a standard two-year warranty.
FactoryMation LLC, 135 Wes Walker Memorial Dr., Ball Ground, GA 30107, (800) 972-0436, factorymation.com
