Float Switch
A reliable and economical solution to low-level sensing, the L001 float switch is ideal for condensate pans, steam tables, warming trays, sumps, and other applications requiring critical low-level switching.
Feb. 3, 2005
Constructed of FDA-compliant polypropylene, the device actuates at levels as low as 3/8 in. of water, is rated for 150 psig, and withstands temperatures to 200°F. The L001 is top mounted with a standard 1/ 8-in. NPT or 3/ 8-in. thread or base mounted at the tank bottom using a special adhesive-backed mounting. The device can be supplied with Buna-N floats for oils, gasoline, and low-density fluids.
Innovative Solutions,
60 Great Hill Rd., Naugatuck, CT 06770,
(203) 729-6434, innovativesensing.com
