Vacuum Regulator
The VRD single-stage diaphragm vacuum regulator is designed to control output vacuum from 0 psig to full vacuum.
It targets low-vacuum regulation such as 1/2 psig. The VRD's ultraminiature, lightweight design allows convenient in-line mounting without the need for panel mounting. The unit weighs 30 gm in brass and stainless steel and is 35/64-in. high. The VRD features Buna-N seals and 10-32 UNF inlet and outlet ports.
Beswick Engineering Co. Inc.
284 Ocean Rd.
Greenland, NH 03840
(603) 433-1188
