Shaft-Grounding Ring
It channels harmful shaft currents away from bearings to ground. To facilitate field retrofits on coupled equipment, the maintenance-free split-ring iPro comes in mating halves. The iPro safely diverts up to 120 A of continuous shaft current. The devices work even if oil, dirt, or grease contaminate the shaft.
Electro Static Technology, 31 Winterbrook Rd., Mechanic Falls, ME 04256, (866) 738-1857, est-aegis.com
