Software For Data-Matrix Decoding
Feb. 17, 2005
VCM200 V4.1 Data Matrix Code Reader software deciphers rectangular and square ECC 200 data-matrix codes with module sizes from 6 X 6 up to 144 X 144.
An autodetection mode determines a size, number of modules, and bright-on-dark or dark-on-bright code types and adjusts the reader engine accordingly. The software can read the codes as fast as 40 codes/sec when running on the latest DSP processors. Accuracy is good even when code is damaged, distorted, or poorly printed.
Vision Components,
10 Hedgerow Dr., Hudson, NH 03051,
(603) 598-2588,
vision-comp.com
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
