Tactile Switches
HP and CB Series of environmentally friendly, through-hole and surface-mount tactile switches feature 6-mm-square bodies with terminals and gold or silver contacts.
The HP Series is rated at 500,000 operations (minimum) for both electrical and mechanical life. A CB Series has sealed bodies to prevent contamination during soldering and cleaning, and is rated for an electrical and mechanical life (minimum) of 100,000 operations. Crimped terminals on through-hole models ensure secure mounting and prevent dislodging during soldering. Surface-mount versions have gull-wing terminals for mechanical stability. Actuators are flat with thin profiles. All actuators and bases meet UL flammability ratings for 94V-0.
NKK Switches,
7850 E. Gelding Dr., Scottsdale, AZ 85260,
(480) 991-0942,
nkkswitches.com
