Axial-Piston Pump
The PVWH open-loop, axial-piston pump comes in 10 different sizes and reaches 5,000-psi maximum pressure.
July 13, 2006
The pump's 11 types of control allow field interchangeability without disconnecting from the drive or system piping. Features of the PVWH include rugged cylinder design; valve plate ported rear or top and bottom; quiet valve plate — all sizes are below 80 dBa at all pressures; SAE heavy-duty shaft, high-strength through-shaft availability; and maximum displacements ranging from 0.66 to 7.94 in.3/rev.
The Oilgear Co., 2300 S. 51st St., Box 343924, Milwaukee, WI 53234, (414) 327-1700, oilgear.com
