DC-DC Converters
The 1.5 to 25-W CC-E Series of dc-dc converters are designed for use in applications ranging from process control to communications equipment.
The Series consists of 68 models with power ratings of 1.5, 3, 6, 10, 15, and 25 W. Models with 10-W or less can be supplied with 5, 12, 24, and 48-V nominal input and output voltages of 3.3, 5, 12, ±12, and ±15. The 15 and 25-W Models come with a 24-V input and output voltages of 3.3 and 5 V. Dual-output units can be configured as 24 or 30-V single outputs. Six package sizes range from 0.65 X 0.654 X 0.335 in. (1.5-W Models) to 1.7 X 1.77 X 0.295 in. (25-W Models). The RoHScompliant devices conform to UL, CSA, and EU Standards. The units operate from -40 to 85°C and have an input-to-output isolation of 500 Vac. A remote on-off and output trim feature is available.
Lambda, 3055 Del Sol Blvd., San Diego, CA 92154, (800) 526-2324, lambdapower.com
