Inch-Dimension Linear Ball Bearings
A new Series of inch-dimension linear ball bearings feature a compact design and recirculating balls that reduce friction for fast and precise load transport in linear-guide applications.
June 17, 2004
INCH-DIMENSION LINEAR BALL BEARINGS
The bearings are available unmounted or in an aluminum housing. They come in open and closed designs in standard or corrosion-resistant versions, self-aligning, adjustable-clearance, and tandem linear ball-bearing units. All units come with integral seals.
SKF Motion Technologies,
1530 Valley Center Pkwy., Bethlehem, PA 18017,
(800) 541-3624,
www.linearmotion.skf.com
