Curvilinear Sensor
The C-Series is a magnetostrictive position sensor that provides curvilinear measurements where less than 270° of shaft rotation must be monitored.
The C-Series is a magnetostrictive position sensor that provides curvilinear measurements where less than 270° of shaft rotation must be monitored. Housed in an IP67-rated enclosure, the housing can also be curved to fit special applications and has a larger measurement range when using the standard stainless-steel float for liquid-level applications. The sensor has optional 5 or 12-V supply modules to meet power requirements.
MTS Systems Corp., 3001 Sheldon Dr., Cary, NC 27513, (919) 677-0100, mts.com
