Power ratings of the BF Series are 0.075 to 50 hp with output speeds of 0.3 to 230 rpm and a torque range of 840 to 163,700 lbf-in. The motors have a highquality insulated-enameled copper-wire stator winding, an aluminum die-cast cage rotor, and high-tensile, case-hard steel gear wheels. A state-of-the-art, fully enclosedgearbox housing is vibration resistant, noise absorbent, and protects from dust, water spray, lubricant loss, and dirt buildup.
