The Magelis XBT-R matrix screen display accommodates up to four lines of large font (20-mm-high) text for easy viewing. The Magelis display is designed to provide an affordable HMI display for small-and medium-sized machines. It is rated for IEC 60529, NEMA 4X outdoor use, Class I Div II and UL508, the sturdy The display terminal features an ergonomically designed keyboard with 20 keys and ports to handle either point-to-point or multi-point communications. It provides low-cost connectivity to PLCs using Modbus and Uni-Telway protocols and supports Latin, Cyrillic, Katakana, Greek and Chinese fonts.
Schneider Electric, 1415 South Roselle Road, Palatine, IL 60067-7399, (847) 397-2600, www.us.telemecanique.com
