Plug-In PLC
The Solves-It! plug-in PLC functions as a drum sequencer, high-speed counter, time-delay relay, or real-time clock.
The PLC programs in ladder logic with function block using EZ Ladder Lite software. Two models are available: Both the SI-100 and SI200 have four inputs and four outputs with four programmable LEDs. The SI-200 also has a four-digit numeric display, real-time clock, and two pushbuttons. An optional Quick Start kit includes the Solves-It!, programmable cable, screw-terminal socket, and the software.
Divelbiss Corp., 9778 Mt. Gilead Rd., Fredericktown, OH 43050, (800) 245-2327, divelbiss.com
