Easy-To-Open Filter Covers
Flowline filter housings feature covers that open and close in any of four directions with ordinary hand tools.
May 11, 2006
This reduces installation costs because piping changes no longer need be hampered by obstructions that would complicate cover removal. And if piping layouts change, the cover can reorient to open in a different position. Housings are lightweight yet strong enough for heavyduty installations. They feature easy-to-clean surfaces with few internal welds and smooth bead-blasted finishes. They come in carbon steel or Type-316 stainless steel and fit all standard single-length 01 and doublelength 02 filter bags. A choice of 2-in. ANSI flanged or 2-in. NPT threaded piping connections are available.
Eaton Filtration LLC, 900 Fairmount Ave., Elizabeth, NJ 07207, (908) 787-1000, eaton.com
