Incremental Wheel Encoder
Sept. 27, 2007
The DKV 60 Incremental Measuring Wheel Encoder provides reliable speed and position feedback in conveyor-belt applications.
The unit features IP65 protection with a robust design that’s resistant to high levels of shock and vibration. Options available include an extended length cable to 1.5 m, a knurled or O-ring surface measuring drum, and TTL/RS-422 or HTL/push-pull interface options. The design is said to eliminate the eccentricity errors of the code disk, ball bearings, and shaft common to conventional systems.
Sick Stegmann, 7496 Webster St., Dayton, OH 45414, (800) 811-9110, stegmann.com
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
