Pump Is A Drop-In Replacement
The Titan C22 general-purpose industrial pump is a drop-in replacement for seepex BN Series pumps from seepex GmbH, Germany.
Pump is a drop-in replacement
All internal components are interchangeable with Titan C22 replacement parts. The drop-in feature reduces downtime and eliminates long delays waiting for imported replacements. Features of the Titan C22 include flow capacities of 500 gpm and pressure to 175 psi. Bushed pin joints allow selecting material for reduced product wear. Rotors have double the industry standard of hard-chrome plating thickness, elastomer seals are at each end of the stator, and the pump sports a conventional rotor/stator design. The pump's block design allows a close-coupled drive.
Tarby, 2205 E.L. Anderson Blvd., Claremore, OK 74017,
(800) 854-1879, tarby.com
