Leveling Casters
LevelCasters serve as casters as well as a leveling mounts for equipment that may need to be moved after installation.
The lightweight casters are strong enough to handle loads from 25 to 800 lb. Constructed of durable formed steel, they have large 2.83-in.-diameter nylon wheels and ball bearings that can be adjusted and repositioned under full load. The casters adjust by hand with 360° of freedom. Dual mounting designs are also available.
Sunnex Inc.
3 Huron Dr.
Natick, MA 01760
(800) 445-7869
sunnexonline.com
