Thermally Conductive Metal Composite
AlSiC (Aluminum Silicon Carbide), a metal-matrix composite, is said to be ideal for thermal management of high-flux LEDs, such as signal lamps, back lighting for signs, low-profile luminaries, task lighting, and display lighting.
Jan. 6, 2005
The material's high thermal conductivity (200 W/mK) lets it achieve maximum brightness in LED lamps at the lowest possible operating temperature. Unlike copper and aluminum metals that have high thermal-expansion values, AlSiC has a low coefficient of thermal expansion (CTE). This minimizes thermally induced stress and reduces failures of delamination and cracking. This reduction improves LED reliability. With a compatible CTE value, the need for thermal stress compensating interface layers is also eliminated. A net-shape fabrication process produces the material and fabricates product geometry, including throughhole and threaded-hole features. This cost-effective process allows tight tolerances without machining and provides high-volume assembly yields. The casting process also simplifies use of high thermal conductivity inserts (>1,000 W/mK) for thermal dissipation.
CPS Corp.,
111 S. Worcester St., Chartley, MA 02712,
(508) 222-0614, alsic.com
