LED Indicators
The Q-Series of LED indicators comes in red, green, yellow, blue, and white along with optional bicolor, tricolor, and flashing versions.
Termination is by solder lug, quickconnect, wire lead, and 200-mm extended wire. Package sizes are 6, 8, and 14 mm and come with prominent, recessed, or flushbezel styles in bright-chrome, blackchrome, or satin-gray finishes. Integral resistors permit direct connection to 12 or 24-Vac or dc and 110 or 220 Vac. Viewing angles range from 70 to 100°, based on bezel options. Life expectancy is 100,000 hr at operating temperatures from 40 to 85°C. Special options include high-brightness, sunlight-readable LEDs and panel sealing to IP67.
Apem Components Inc., 63 Neck Rd., Haverhill, MA 01835, (978) 372-1602, apem.com
