Parts-Handling System
March 22, 2007
The Versa-Stack Parts Handling System relies on Feedscape ID feeding technology and an MS Series indexer to create stacks of different components.
The Versa-Stack Parts Handling System relies on Feedscape ID feeding technology and an MS Series indexer to create stacks of different components. Feedscape isolates and feeds components directly from a bowl feeder or spring feeder, then guides them onto a series of indexing pins on the outer edge of the indexer dial plate. Once the stack is complete, an escapement deposits the stack on the final fixture, pick-and-place unit, or robot. Feedscape and the indexer can be configured from the keypad. And each stack arrangement can differ from the previous one, without tooling changes.
Centricity Corp.,
25 S. State St., Girard, OH 44420,
(330) 545-5624,
centricity.net
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
