Ball-Screw Positioning Tables
IDC URS-Series ball-screw positioning tables use a special "U"-shaped steel guide rail and a recirculating bearing module that serves as both a guide block and ball-screw nut.
Oct. 21, 2004
BALL-SCREW POSITIONING TABLES
The bearing module contains four preloaded ball circuits for high load capacity, accuracy, and rigidity while the rigid "U"-shaped guide resists bending for cantilevered applications.
The URS-Series comes in five standard sizes from 20-mm tall by 40-mm wide to 55-mm tall by 100-mm wide in travel lengths to 1,134 mm and load capacities to 530 kg.
Danaher Motion, 1500 Mittel Blvd., Wood Dale, IL 60191, (866) 993-2624, danahermotion.com
