Sealed-Rocker Switches
The KR series rocker switches are available in single and double pole models with solder lug/quick-connect or screw terminals.
The terminals can have silver UL94-VO rated plastic contacts. They are rated up to 15 A at 12 Vdc for 10,000 cycles, have an initial contact resistance of 10 milliohms, insulation resistance of 1,000 megohms at 500 Vdc, and dielectric strength of 2,000 Vrms between terminals. The series is available with lug/quick-connect and screw terminals made of silver contacts or UL94-VO rated engineered plastics. The switches can be mounted into a 1.45 x 0.83 in. panel cut-out.
APEM Components Inc., > 63 Neck Rd., Haverhill, MA 01835, (978) 372-1602, www.apem.com
