Rotational Moldable Polyethylenes
Feb. 23, 2006
Two rotational-molding polyethylenes are using proprietary technology that eliminates pellet grinding.
Borecene Compact RM 8346-9004 and Compact RM 8346-1000 mold easier, thanks to high-flow properties. They also reportedly produce parts with better surface properties. They can be used in high-performance applications and with intricate shapes. Compact RM 8346-9004 is a black grade with high barrier properties, making it suitable for diesel fuel tanks. Compact RM 8346-1000 is a natural grade with high UV resistance and can serve in diesel fuel tanks, toys, and marine applications.
Borealis Compounds LLC, 176 Thomas Rd., Port Murray, NJ 07865, (908) 850-6200, borealisgroup.com
