Panel PC And Automation Panels
Panel PC 300 makes a Panel 900 an embedded PC based on a 500-MHz processor.
Panel PC 300 makes a Panel 900 an embedded PC based on a 500-MHz processor. It has 256 Mbytes of SDRAM, Ethernet 10/100, a serial interface, and support for USB 2.0 interfaces. The 900 handles applications that do not require the computing power of an APC620. It comes in 10.4-in. VGA, 12.1-in. SVGA, 15-in. XGA, or 17/19-in. SXGA resolutions, with touch-screens and keys. The 300 does not need a fan, and used with CompactFlash cards, there are no rotating parts.
B&R Industrial Automation Corp., 1325 Northmeadow Pkwy., S-130, Roswell, GA 30076, (770) 772-0400, br-automation.com
