Specially designed brackets and hole patterns handle 1-4U applications. Front and rear brackets feature fixed and adjustable hole locations for compatibility with 5 /8 and 1 /2-in. pitch patterns. Both brackets and fasteners accommodate square, round, or tapped holes. Slide hole patterns are compatible with a variety of chassis and gives users the option of screw or pin-chassis mounting. The low-profile unit carries loads up to 120 lb and comes in lengths of 22, 24, and 26 in. A lockout function to hold the chassis stable and a lever disconnect provides trouble-free removal and reinsertion.
Accuride International Inc., 12311 Shoemaker Ave., Santa Fe Springs, CA 90670, (562) 903-0200, accuride.com
Sponsored Picks
Sponsored
Sponsored
