Resistive ratings are 30 A at 125 Vac and 30 A at 250 Vac and 30 Vdc. Switches with inductive load ratings of 30 A to 125 Vac and 30 A at 250 Vac can also be configured. Constructed of urea resin in white, the actuators sit in a steel frame with chrome plating over nickel plating. Mechanical life is rated at 50,000 operations minimum and electrical life rating is 25,000 operations minimum. Operating forces vary from 800 to 2,200 g.
NKK Switches, 7850 E. Gelding Dr., Scottsdale, AZ 85260, (480) 991-0942, nkkswitches.com
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
