720-W Low-Profile Power Supply
A new line of switching regulated power supplies feature power outputs to 720 W in a low-profile case for use in 1U rack environments.
July 12, 2007
A new line of switching regulated power supplies feature power outputs to 720 W in a low-profile case for use in 1U rack environments. Available in single-output and wide-range output models, the supplies also sport ac and dc input models. All models provide either constant voltage or constant current. Models with wide output voltage ranges are adjustable down to zero volts, and both voltage and current are programmable with a 0-to-10-V control voltage input. Provisions for N+1 redundancy and paralleling for higher current are optional. Other features include universal input, soft-start operation, Vout OK indication, and no-load operation.
Acopian, Box 638, Easton, PA 18044, (800) 523-9478, acopian.com
