VXI Adapter Card
The VCDS VME to VXI adapter card is a singlewidth, C-size VXI module that adapts most B-size VME modules for use in a VXI mainframe.
The VCDS adapter maintains the VMEbus environment, timing, and backplane by buffering the VME address bus, data bus, and control signals and routing them to the installed VME module. It supports seven interrupt levels and eight TTL trigger lines as well as two ECL trigger lines.
KineticSystems Co., 900 N. State St., Lockport, IL 60441, (800) 328-2669, kscorp.com
