New Products: 1.54-to-80-MHz ceramic SMD oscillators
The MXH Series of oscillators measures 2 2.5 mm and operates at supply voltages as low as 1.6 Vdc. Current draw is typically 8 mA at full power and 30 μA on standby. Operating temperature range is 40 to 85ºC; frequency stability is as tight as ±25 ppm; maximum start-up time is 10 msec with a rise and fall time of 4 nsec; and the aging rate is ±5 ppm for the first year. Waveform output is HCMOS compatible and tri-state functionality comes standard.
MMD Components, 30400 Esperanza, Rancho Santa Margarita, CA 92688, (877) 663-2667, mmdcomp.com
