New Product: Ac/dc power supplies
Two versions, the 10-W ECL 10 and 15-W ECL15, are available in three mechanical formats: openframe PCB mount, encapsulated PCB mount, and open-frame chassis mount. The ECL10 open-frame PCB-mount unit measures 1.0 2.0 0.9 in. and has a power density of 5.6 W/in.3
Both units are available in 3.3, 5, 9, 12, 15, 24, and 48-Vdc output voltage. Full power range is 85 to 264 Vac or 120 to 370 Vdc. The units operate at 20° to 70°C, with derating above 50°C. Peak load capability is 130% of nominal, for up to 30 sec. This feature means that, for applications that require higher peak power, the ECL series can be specified in place of higher power, more expensive devices.
XP Power, 305 Foster St., Littleton, MA 01460, (978) 287-7260, xppower.com
