Melt-Processible UHMWPE
March 9, 2006
Ultrahigh-molecular-weight polyethylenes (UHMWPW) are now melt processible.
The Luvotech line of UHMWPE compounds can be extruded or injection molded using standard equipment. The compounds have physical properties similar to traditional ram-extruded or compression-molded UHMWPE grades, including high wear resistance and good lubricity and hardness. Luvotech TLC10528 is the standard natural-white grade, but other custom colors are available, including deep tones and bright hues.
Techmer Lehvoss Compounds LLC, #1 Quality Circle, Clinton, TN 37716, (865) 425-2121, www.tlcompounds.com
July 17, 2024
July 10, 2024
Pumps Push the Boundaries of Low Temperature Technology
June 14, 2024
As an integral part of cryotechnology, KNF pumps facilitate scientific advances in cryostats, allowing them to push temperature boundaries and approach absolute zero.
The entire spectrum of drive technology
June 5, 2024
Read exciting stories about all aspects of maxon drive technology in our magazine.
