Biodegradable Rust Preventative
Water-based BioCorr Rust Preventative provides long-term corrosion protection for metal products during shipment and storage.
Made from soybeans, the biodegradable formulation is ready to use and provides indoor rust protection by leaving a thin dry film on the surface of steel, stainless steel, aluminum, and yellow metals for up to two years.
Cortec Corp.,
4119 White Bear Pkwy., St. Paul, MN 55110,
(800) 426-7832,
cortecvci.com
