SBC Uses Low-Power Celeron M
The PCA-6189-C1A1 is a fanless single-board computer that uses an ultralow-power Celeron-M processor at 1.0 GHz along with the Intel 855GME chipset.
The system supports dual-VGA displays along with DVI and an onboard LVDS. The board CPU uses 5 W of power and is based on the PCA-6189 configuration for high stability and a reduced RMA rate. The board provides two SATA HDDs, 64-bit/66-MHz PCI-X interface, dual Gbit-Ethernet adapters, and SATA RAID 0, 1 drive software and compact flash socket for expansion capacity and data backup.
Advantech Corp., 1320 Kemper Meadow Dr., Cincinnati, OH 45240, (800) 205-7940, eautomationpro.com/us
