Flow transmitter
The MR flow transmitter is a variable-area flow meter providing a digital display of both flow rate and total accumulated flow.
The meter has no magnetic couplings or mechanical linkages, making it suitable for high-cycle, transient-flow applications. Calibration parameters such as pressure, temperature, and specific gravity compensation for water, petroleum, and pneumatic applications are field adjustable using configurable soft switches. The meter has a 4 to 20-mA currentloop output as well as 0-to-5 and 0-to-10-Vdc voltage outputs.
Hedland Flow Meters,
8635 Washington-Ave., Racine, WI 53406,
(800) 433-5263,
hedlands.com
