The epoxy has a 2-hr work life, permitting use for large projects. It also has a low coefficient of thermal expansion, minimizing read-through from honeycomb cores to panel surfaces. The epoxy has a 1:1 mix ratio and a spreadable viscosity of 43,000 cP. Bonded panels can be handled after 24 hr at room temperature or 15 min after curing at 212F (100C). The epoxy's fully cured shear strength is 3,000 psi.
Huntsman Advanced Materials Americas Inc.,
5121 San Fernando Rd. W, Los Angeles, CA 90039,
(818) 247-6210, www.araldite.com
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
