New Products: Tie-rod hydraulic cylinders
The products have bore sizes from 10 to 30 in., stroke lengths to 300 in., and best-in-class options. The cylinders feature ultraheavy-duty rolled tie rods, high-yield-strength tubes and pistons, steel heads/caps, a secured piston rod for continuous performance, a cushion design that increases linearity and smooths operation, and a piston and rod sealing system for more flexibility, customization, and increased life.
Eaton Corp., Hydraulics Operations, 14815 Lone Oak Rd., Eden Prairie, MN 55344, (888) 258-0222, hydraulics.eaton.com
