High-Density SSRS
May 25, 2006
CK Series solid-state relays mount to a DIN rail and come in either single or dual-relay versions with spring clamp connections.
The relays target equipment requiring a high number of switch cycles and are effective when panel space is at a premium. They come equipped with one 5-A relay or with two 2.5-A relays. They use PTC push-in jumpers that are inexpensive and can be cut to any number of positions. The jumper simplifies the task of commoning inputs and outputs. The CKS Series can switch solenoids operating from up to 1 S. All relays are soldered-in to promote shock and vibration resistance.
Automation Systems Interconnect Inc., Box 1230, Carlisle, PA 17013, (877) 650-5160, www.asi-ez.com
Clean. Compact. Less heat.
April 16, 2025
