Pneumatic Wash-Down Valves
Sept. 15, 2005
The Clean Line CL03 Series of pneumatic valves stand up to aggressive detergents and chemicals used to disinfect food-processing and packaging lines.
They have IP69K protection class ratings for high-pressure wash-downs to 1,450 psi. This eliminates the need for protective cabinetry and helps improve performance because they can be closely positioned to actuators. They come with multipin connections or serial communication options for major protocols. The valves feature flow rates to 0.85 Cv and can handle up to 32 different pressures.
Bosch Rexroth Corp., 5150 Prairie Stone Pkwy., Hoffman Estates, IL 60192 (847) 645-3600, www.boschrexroth-us.com
June 27, 2025
June 25, 2025
June 25, 2025
