Surface-Mount Resistors
Surface-mount Bulk Metal Z foil resistors are for automatic test equipment, high-precision instruments, laboratory, high-end audio gear, and other applications.
The resistors are ultraprecise and stable. They feature a flip-chip configuration for a good power-to-size ratio. The resistors are not sensitive to surrounding temperature variations and applied power changes. Lead-free and tin-lead alloy terminal-finishes are available.
Vishay Intertechnology Inc., 63 Lincoln Highway, Malvern, PA 19355, www.vishay.com
