Model PH-1300 Proheat VariAir heat guns allow precise control of temperature from 130 to 900°F and airflow from 1,425 to 3,550 fpm. A closed-loop feedback circuit maintains constant temperature at all airflow settings when using any of five available attachments.The guns are compact, lightweight, and ergonomically designed for proper balance and grip with convenient, top-mounted, dial-in controls for easy temperature and airflow adjustment. Applications in the automotive, electronic, laboratory, and general industrial markets include soldering and desoldering, heating of temperature-sensitive materials, plastic bending and forming, resin curing, drying filler, shrinking tubing, and others. For dedicated heat-shrink applications, the PH-1300 comes with a bench stand and special shrink attachment.
Master Appliance Corp.,
2420 18th St., Racine, WI 53403,
(800) 558-9413,
masterappliance.com
